Steering damper
2463 Views 10 Replies 7 Participants Last post by  assassin
The question has was probably all ready been ask but I can't find it...
I have a 2000 TL1000s and I wan't know if I can install a aftermarket steering damper without the transversal mount and using the OEM mount.
I know you can do it on the TLr but on the TLs??
Thanks.
hmmmm....i have mine fitted along the side of the tank but its a special bracket specific to my top yoke with risers and bars...
any will work as long as the stroke is the same i think....i think you'll find most manufacturers do many different lengths..if you can find out what other bikes have a similair stroke ( 75mm i think? ) then it will be easy enough to pick one up :thumbup
Mine is a Sprint (ignore the sticker on the damper :laugh) damper mounted in front of the tank also, the Sprint damper doesn't use the oem mount.
sorry for the hijack..who painted your bodywork chris?
I want to take this opportunity to plug the Hyperpro RSC, just because I was SO please with it.
i've got a csc..can't wait to try it!
I had a matris damper on the TLs, fits on the OEM position.
Not every damper fits because the ignition key is in the way.
The damper is for sale btw.
cheers, tlh
hi, I am using trible performance damper which are produced by my friend and custom mount, which is my work(I do some mounts for trible performance)
