Ride it like you stole it. :devious
TLS CF cans;homemade SATRE;Airbox mod;K&N airfilter;'97 temp sensor mod;Iridium plugs;SV1000Coils;TLR bellmouths;OEM-style smoked screen;HH sintered pads front and rear;Metal Gear rotors;OEM mirror mounts blanked;bar-end mirror;short rear fender with homemade numberplate/indicator bracket;damper mount mod;Riflemans clear clutch cover and 1/5 throttle insert;Barnett clutch springs;Mini indicators;2.5wt oil in stock damper;PC II;Bitubo rear shock;Forks up 5mm with Race Tech internals - 1kg/mm springs, custom shimstack,re-valve, piston and cartridge kit;braided front brake line;billet sprocket cover;charging mod;plus mod;clutch-switch relay by-pass;stainless xhaust studs/brass nuts;welded clutch...
TLR 'Fighter: http://www.tlzone.net/forums/suzuki-tl1000r-tl1000s-forum/136603-my-tlr-streetfighter-build-2.html
