1 - 8 of 8 Posts
Hiya I have a streetfighter tl1000s and the standard clocks look crap (in streetfighter form) dont want to go down the chineese clock route , I looked at tl100r clocks but they are £££ second hand. But srad 600/750 clocks look the same just highter revs on the counter, has anybody tried fitting a set ? Trying to make it look ok and still have the full functionality of the clocks etc 🙂
Kind regards sam
Never tried to put SRAD clocks to the TLS. However, keep in mind that (afaik) all 600 SRADs are carb'd, and only later 750 SRADs models have eFI. All 'carb'd clocks' won't work on the TLS because they can not display FI errors or TPS data. They only do display the coolant temp, and that also is not compatible with the ECU message that the TLS expects. SRAD clock from a eFI SRAD 750 most likely will work on the TLS. It might be required to add a signal level converter to the tacho circuit to shift the TLS's 5V rpm signal to 12V as is required for the TLR clocks.
I'd suggest to get a GSXR 1000 K1 to K4 (K5/K6) or a SV1000 speedo. All those can be made working on the TLS.
Hiya thanks for the info guys I'll send the clocks back I ordered lol could be interested in the cagiva clocks how much did you want for them mate ?
1 - 8 of 8 Posts
