1 - 2 of 2 Posts
Started the bike up today and i'm hearing some type of squeaking noise from the front of the bike, possibly in the engine. I can't nail it down. It happens in the first little turn of the throttle, but only squeaks briefly. Then when I let the throtle off and then twist it again, it squeaks again. Also does it during downshifting when I let out the clutch and when I turn the engine off. I just installed a GPI w/ATRE this weekend and a K&N Filter. Did I screw something up???
Discussion Starter · #2 ·
it is definately in the engine. The squeaking noise can be heard when the tach reaches around 2500 rpms on the way up only, makes the noise for a half a second, and then no more until 2500 again...ie..switching gears. It also can be heard when the engine is shut off. What's goin on in there!
1 - 2 of 2 Posts
