1 - 1 of 1 Posts
Good through December 31st...
GALFER STAINLESS FRONT LINES + 1375 HH PADS + Motul 5.1 fluid!
Galfer braided stainless lines are a massive improvement over stock rubber brake hoses. With rubber brake hoses the line must flex/expand before any braking pressure can be applied to the pistons, slowing down response time and making the lever feel "spongy". OEM rubber hoses also do not hold up well to heat and cold cycles over the years. Galfer's 2-line racing kits come with all necessary hardware & washers to change out the stock set. Lines have silver fittings and your choice of clear, black, dark smoke, blue, yellow, orange, green, or red outer coating.
Galfer can do kits with colored banjo fittings and colored banjo bolts. Anodized colors include gold, blue, red, or black. NOTE: All color options except silver/clear requires a 2-3 WEEK build-to-order lead time with Galfer.
The deal includes Galfer's 1375 HH brake pads (the proper set to do both calipers for the front) for a great package. The HH compound is a sintered bronzed base material that includes graphite and advance ceramics. It will provide instant powerful controlled braking force at any speed or temperature, rainy or dry weather. Great lasting power for track days and street riding where you want immediate stopping power (15% higher friction rating than EBC*). Compared to the 1370 HH compound, the 1375 compound has a ceramic back coating for a better thermal barrier resulting in less heat transfer to your pistons/fluid!
*EBC advertises their HH pads at 0.6u while Galfer HH pads are rated at 0.7u
For a step up in brake fluid performance, we're including a bottle of Motul 5.1 fluid (compatible with DOT-3 and DOT-4 fluids). Compared to the lower boiling points of OEM brake fluids, Motul 5.1 has a higher boiling point (365 deg F) BUT is more stable (less hydrophilic - meaning less water absorbing) over time than the racing fluids which must be changed out frequently.
Front line kit + front pads + 1 bottle (.5L) Motul 5.1 Brake Fluid:
CURRENT RETAIL PRICE: $190 (2-pad calipers) to $254 (4-pad calipers)
Sale: CALL/EMAIL FOR PRICE or post up to get a PM with a price!
(Gold or blue fittings + $10)
(Gold or red bolts + $15)
Add SS rear brake or clutch line to either kit above, also at a discounted sale price, or inquire on adding wave rotors to your kit!
Add semi-metallic (black compound) rear brake pads (we suggest this over HH rear pads due to the low thermal-demand tolerance of most OEM rear rotors AND the fact that unless you're racing you rarely use the rear and would be better served with a longer-life pad)
Shipping is via UPS Ground insured, ranging from $8-14 to most US locations. We only charge sales tax in ID. International orders will ship US Postal.
If you have tech questions, post here, call toll free 877-234-5150x3, or email me.
1 - 1 of 1 Posts
