Iridium won't give you anything in performance but it will give the plugs longevity. Since changing TL plugs can be a pig this makes them worthwhile. Coils are the same parts for the R and S.
Best thing you can do is make sure your electrical system is in generally good order so the current delivery to the coils is as good as it can be.
Something of a stuck record on this point but I recommend fitting a Lithium battery if you haven't already done so. IMHO its about the biggest and simplest single electrical upgrade you can do. Costs a bit but worth every penny.
