Hi everybody.
My bike wont start and I checked the spark plugs. They are working. It seems like it has no ignition.
The problem started with the bike starting, but as soon as I tried to go, it stopped. There was no power to get me going.
And another thing. Which way is "more gas" and which is less, in the screw for tuning the RPM.:O
Do a search on electrical problems , starter solenoid , molty pole plugs , connectors etc etc
The connector on the starter solenoid and one other large white connector in the whirring harness are known to have corrosion problems.
There’s heaps of good help and what to check including pictures.
Clockwise on the idle screw holds the throttle plate open more...
I'm afraid I really don't understand what your problem is. Does the bike just not start? If so, what does it do when you turn the key on and try to start? A bit more info would be helpful.
good luck
If it runs but won't rev until you really nail it, then the plugs are fouled. Change the plugs first. It is a TLS so make sure you put CR8EK in it, the 9's foul easier.
