1 - 20 of 29 Posts
I thought you had most of this together?
Haven't we seen photos of it mostly built?
yes,its almost time for some colour ;)
if im lucky its ready for MOT in august
i wanted to build it to be sure on riding position etc. and to see how my colours/parts would look when ready!
it is my 50th birtday present,so i want it to be perfect!
Here's a tip.
When I went on my shake down rides, short 10 minute local runs I found every bolt on both sides of the ally plates was loosened and I even lost one!
make sure you lock tight them in!
how are you going to stop the side stand rotating?
how are you going to support the exhaust by the footpeg / swingarm location?
...I found every bolt on both sides of the ally plates was loosened and I even lost one!
Were they tightened to spec? Clean mounting surfaces? Although the assembling instructions says "Check all screws for proper tightness after the first 500 kms", I never had to re-tighten any of those screws, never had a problem with loosened or even lost screws. Strange...
Here's a tip.
i have an alu plate bolted to the cases to prevent the rotation and there is a bracket that bolts between right sideplate and engine for securing the exhaust.
and yes,Loctite is ready!
they were as tight as I could get them................. i think there was still some paint on the mating surfaces.............
i have an alu plate bolted ..... a bracket that bolts between right sideplate and engine for securing the exhaust.
Show us some pictures then.................... interested to see how you dun it....................
that aluminium bolts to the cases!
exhaust mount
This is how the bracket is fixed on my UNO (ss-switch removed). There's an additional tab on the rear header where the side stand bracket is attached to.
The bracket that comes with the frame kit.
Click for larger pics.
Discussion Starter #11
Thanks JoE!
maybe Ted gets it now
I never got either of those with my frame..................
I made one up similar to yours Troy for the side stand and found it bent after the Euro trip so I made another twice as thick.
I also found that even with spacers the faces of the side stand and the engine case mount were at slightly different angles so to not allow the bracket to sit flat.
I have also adjusted the side stand to have the bike lean over at less of an angle to try and lessen the weight on it.
I think I might re-visit mine in the not too distant future as if yours and JoE's do sit flat then my side stand mount might be a little bent.
As for the exhaust mount, I have black Yoshi rearsets so I took an ally bracket painted black down from those 2 fixing points, put a dogleg in it and fixed the exhaust that way.
Discussion Starter #13
Discussion Starter #14
done some more today
Only the exhaust mount was part of the kit, the one for the side stand is DIY.
I used aluminum 20 x 5mm or 20 x 6mm.
I usually turn the bike on the side stand, so the bike's whole weight is on the stand. No problems whatsoever.
Mine is flat, no bends.
Here is a picture of the DIY bracket I made for the exhaust mount.................
I had to use one inch spacers to mount the foot pegs as well as the thickness of this bracket to get the levers out far enough to miss the ally side plates.
I remade mine from 10mm ally...........
I have a spare or two of side stands so I will re-visit that. My fixing points are deffo at a slightly different angle to each other.
Discussion Starter #17
Done for today
tomorrow i start with the electrics
Discussion Starter #18
Reactions: Tuckshop Ted
Discussion Starter #19
FIRST START!!
well done! ............ very nice .............. :thumbup
Reactions: Troy
1 - 20 of 29 Posts
