:blush
well i still havent cracked the manual on this motor split. granted ive seen portions of it before. :)
thanks to doug for shooting me his stator tool on a days notice :hail
so whats left? run out the bolts and whack it with a block of wood? :dowhat the cranks turns like a dream, gears and dogs look good too.
ok, i read the manual and it calls for the magic case splitting tool. figures. ive got a slide hammer and some threaded studs.... :banana
Take the bolts out and gently smack it with a mallet and it will come apart nicely
Make sure you remove the cam chain shaft first. :thumbup
Best to make a template out of cardboard, so you know which bolts go where. :yes
Love the old school crank case splitting tools in the last photo.....................Hammer and Screwdriver :laugh
how that the cam chain shaft come out? i see the phillips bearing retainer.
thanks guys. :banana
this is fun.
You need the flywheel on to hold while you undo the left handed nut on the primary shaft, look at the manual, it makes it easier, the order is important :coocoo
i think its already off. see the third picture :coocoo :laugh
im usually all about the manual.
Yes you got it, should be easy now, I believe you should lay it clutch side up and smack it a bit and you get this
Man, that looks like FUN... so long as it didn't have to go back together (if it were me). BTW, I just sold my old hippy copy of Muir's How To Work On VW's last week. Funny read.
DIY Crankcase splitter.
Very usefull.
Discussion Starter #13
woo hoo !
thanks guys, especially doug and les. everything looks honky dory :banana
Woo Hoo!
