Hey man, just a tip. When doing up close detail shots of your stuff, look for this option on your camera in order to shift the focusing mode to macro, or close up.
How did it manage to do that? over rev?
Hopefully just new valves, There is a chance the guides may be FUBAR too.
Discussion Starter · #8 ·
Had the engine out all last winter doing little things to it, and when I installed everything again I forgot to torque the cam bolt and ran it up to redline after riding it around easy a while and out she came. Im going to take it down to a very trusted shop and let them take a more edjucated look at it. Ive already priced everything at retail and its not too bad, shop will give it to me just above cost if not at with shop labor.
Discussion Starter · #10 ·
ive got a second engine sitting in the garge now, but would perfer my current engine over a 97 version.
Besides if I can get one fixed, I can part with the other. regardless ill probably be parting with pieces of one.
DOH I bet new valves and you'll be good to go though:thumbup
swap the heads and cam caps from your other motor and call it a day :O
yeah, replaced the valves on my mazda without checking the guides. it runs better, but burns a lot of oil on startup and a bit on higher revs. new guides in a couple of weeks though (along with ANOTHER head gasket - not cheap them mazda ones!)
