21 - 40 of 222 Posts
great work dude...:hail
yup BP, that's what I was talking about.
I forgot to mention that I found myself giggling out loud here at work looking at those photos.
Great work Sam:hail I don't suppose we will see it at the BMF this May then:O:laugh
:hail:hail
nice one Sam :hail
Discussion Starter #26
After a go on this beast you'll be giving the ktm the same treatment I suppose:devious
I can only wonder if the clutch will hold up with that kind of power. Increasing body mass...............one beer at a time!
I'm working on increasing my body mass to keep the front down :thumbup
There's alot to be said for eating all the pies... :laugh
I was thinking of using the TLR ECU to run the TLS throttle bodies
With the secondary injector drive running a set of shower injectors.
That way you can have programmable ignition & fuel maps.
The flapper actuator can be used to switch on your water injection.
If the fuel pump regulator is referenced from the boost side of the blower
Then having the MAP sensor on the suck side should be fine
there is a cheap aftermarket computer I think called a 'link' made in nz which might be easier
Everything you do always have this touch of perfection, Sam.
Amazing work so far. :hail
Discussion Starter #35
I have some great photo's of the drive etc but keeping them to myself for the minute, don't want somebody with more time getting a jump on me :laugh
:hail its all i can say
All visitors to sam's place will be checked for concealed cameras :laugh
Discussion Starter #38
You'd need an endoscope now the engines bolted together :laugh
You'll definitely have to do a cavity search then, ideal place to stash and endoscope. :crazy
