Does anyone know what the part number is for the sidestand switch for the TLR? Mine is going bad and I would like to replace it.
There is a diode in the switch but there's no need to duplicate it if you want to bypass the switch. Steve or les could probably explain why, but I can verify that simply bridging the wires at the side stand connector works just fine:thumbupgoeland_ said:if you take it off, you have to put a 1N400 diode with right polarity
there's a diode in the sidestand switch
