hello all,
my used tiller didnt come with an owner's manual so i was hoping one of you could help me out. i'm coming up on 12,000 miles. what kind of work needs to be done at 12,000 miles? how often do the valves need to be done? anything else besides oil etc?
thanks
H
Guest
its 15k on the tl for valve adjusts. i know cause mine is getting close.... and i bought her with 6 k on it in march....:)
valve adjust isn't until 15k. the spark plugs should have already been changed once. they should also be done at 15k. maybe flush the brakes, clutch and cooling system.
thanks guys. i appreciate it. looks like i can put off shelling out the valve adjust money for a little while longer. clutch and brake fluid has been changed. will look into flushing cooling system.
thanks again, gotta love communities like this.....:)
