1 - 20 of 29 Posts
I will include postage to UK & Europe in the prices.
USA & Aus I will get a quote for you.
Ohlins rear damper for TLS (SU8052) = £495
Brought new by me, done around 10 - 12k. Good condition, no leaks, works fine, some fitting marks, some wear showing on casing.
All bolts, spacers, mounting bracket & Ohlins Instruction sheet included
. SOLD.
*********** rear damper for TLS = £395
With assister spring - this does not replace the SOAS.
Aquired secondhand by me. About 5k added by me. Works fine. Some abrasion to outside of reservoir link hose.
All bolts, spacers & brackets included.
Chinese rearsets just refurbed & sprayed enamel Black = £50 SOLD
Tank bra = £35
Rifleman clear clutch cover (original plastic with window cut into it) polished and lacquered ring (which had been road rashed) = £50 SOLD
GSXR1000 forks, new seals, resprayed black on black with shims for yoke and spacers for discs & busa spindle.
So plug & play with standard TL wheels and discs.
Gold Tok radial calipers to fit above. 4 pad type.
Gold rear nissin caliper to match above
Nissin (Japan) 3/4 radial brake master, new enamel spray painted black
Nissin (Japan) 3/4 radial clutch master, new enamel spray painted black
Please don't tell me you don't know what a seat hump looks like - or calipers - or masters .....................
Reactions: Troy
Rear sets sold - off to the Netherlands...............
I'm looking for a Black Seat Hump, but not at £55, let alone a lime greeny yellow colour that needs painting lol
Reactions: Troy
Glass is half full my friend. It's a good deal if you don't paint it lol
Don't want much then.............
i think i have one for you,ill check tomorrow!
Reactions: Sam
Discussion Starter · #8 ·
I also have a very nice one for sale, in original novelty black, but it will cost you ...................
I don't need one as it has the standard passenger seat, just be nice to have one to match the rest of the bike if I try and keep it standard, hence why I don't want to pay silly money for one.
If I was pay a lot for one I'd go down the low profile aftermarket version for £80 by Pyramid Plastics that I used to have on my first TLS many years ago lol
Discussion Starter · #10 ·
Master cylinder photos for you...................... titax levers included.
Discussion Starter · #12 ·
Shipping to Canada for the Ohlins?
Postal code: J7T 2L3.
About £40.00 GBP with insurance. About £28.00 without insurance. 8 to 12 days via Canadian Post Office, no signature required.
Hi
Are any of these parts still available?
Also after a few bodywork parts if you have them?
Please PM if you want to take it away from this thread.
Thanks
Steve
Discussion Starter · #14 ·
Forks, levers, rear dampers, calipers & bra still available...........plus pristine red or black original seat hump.
Have you still got the forks and calipers Ted?
Discussion Starter · #16 ·
yes I have, you local?
whats left?
Discussion Starter · #18 · (Edited)
I also have a renntec bolt on rack for the TLS, all in good condition = £65.
Tank bra = £35 posted,
TLS rear seat hump, '97 Red or '97 black, very, very good condition, all there & all working = £85 posted,
GSXR1000 forks, new seals, resprayed black on black with shims for yoke and spacers for discs & busa spindle. So Plug & Play with your TL wheels = £500 posted,
Gold Tok radial calipers to fit above = £165 posted,
Gold rear nissin caliper to match above = £90 posted,
Nissin (Japan) 3/4 radial brake master, new enamel spray painted black = £185 posted,
Nissin (Japan) 3/4 radial clutch master, new enamel spray painted black = £185 posted (posted means to mainland UK only - for ALL items)
Not actually convinced I want to sell all the items yet either....................
I will soon have a pair of very nice Yoshi RS3 bolt on's and a nice complete Yoshi TLS system including RS3 stainless cans, all newly refurbed, repacked and polished.
I will be willing to part with them for the right price........................... they would not be cheap, they will have a mark or two, they are secondhand.
SOLD!
Discussion Starter · #19 · (Edited)
SOLD!
here is a pair of Yoshimura Ally sleeved RS3 bolt on cans if anyone is interested........£400.00 posted (mainland UK)
Fully refurbed, stripped down, cleaned up, sprayed with black satin finish heat proof paint (800 C ). This is a finish Yoshimura used to offer but no longer.
All end caps cleaned and polished, threads cleaned out. New stainless bolts provided.
Cans re-packed & re-sealed, gas proof rivets used. Now good for the next 10,000 miles easily.
Original Yoshimura straps included with new cushion rubbers.
These are older models without provision for any Db killers provided although you can still fit them but will need to drill & tap your own fixing holes.
These cans are not new, they have some marks on them, they are not perfect, they are used, secondhand, part worn, previously loved, check out the pictures.
Discussion Starter · #20 · (Edited)
Also for sale...............
original TLS Owners Manual = £55. SOLD
original "badboy" "00" ECU = £125.
Also some shorty carbon cans = £325. SOLD
1 - 20 of 29 Posts
