1 - 8 of 8 Posts
· Registered
That's a bummer Rick. :(
Don't foul your plugs....;)
Plus, the battery doesn't really charge that great at an idle.
....and the engine doesn't get hot enough to burn off condensation.
Just bundle up and go ride it. (y):D
As said above. Better off just leaving the bikes till march comes around. It'll do more damage starting them every week than not at all. Just keep the battery charged.
Reactions: V2victim
· Registered
I was letting them run for about 15 minutes. I used the high idle lever and had the TL at about 2500 rpm, after it warmed up a bit. I did the same with the FJR and the KLR. At 35 degrees Tony, there'd be a lot of bundling :)
1 - 8 of 8 Posts
