i have a 98 tlr woth 40,000 miles on it and the valve train is lil more noise then before , and was wondering if there is a site out here to show how to run them , thanks for the help lots
Get a service manual and check your clearances, generally they tighten up over time rather than loosen. A lot of folks figure they get loose/louder, but they do not, they tighten as the valve/seat get driven into the head.
Checking the clearance is easy, and if you can get that far, replacing shims is also rather easy.
seems like the intake vales stay a little more in spec and its the exhaust that needs adjusting.
