My 97 tls is awful at low rpm and am pulling my hair out cause i cant figure it out. the only thing i have found out of the ordinary is oil in the airbox poss from crankcase breather but it doesn't use alot of oil
Symptons // ticks over ok but when throttle is snapped open to wot it hiccups then revs,if i blip the throttle she will backfire on the front pot sometimes in the exhaust but mostly up into the airbox and makes the tank move (it's very Fierce)
If i try to pull of aggresivly 90% of the time it'll lock the back wheel and stall.
driving along anything under 3k rpm it'll pop,fart,lose power,surge,backfire and so on it is awful, it would be fair yo say its dangerous, anything over 3k its perfect with good throttle response
This is a list of what i have done so far to fix the problem and none have improved it
1 changed exhausts back to stock and sealed ant exhaust leaks.
2 changed ecm for a newer one cause i know some early ones had probs
3 set tps
4 changed plugs and cut 10mm off plug leads
5 removed tre as i suspected it was duff
6 sync'd tb's and cleaned with brake cleaner, also run injector cleaner in fuel
7 checked valve timing
8 changed air filter to k&n
9 modded charging system
Thats what i have done so far and none has made a substantial difference , also i will point out that its a austrian import and has the pair system fitted (clean air system)
please please please can someone help im at my wits end with it and if i dont sort it im gonna beat it to death with a hammer
Thanks in advance Steve(cat)
3 set tps
