Recently traded my bike for a 01 TLR. The bike had no trouble starting. The bike stared after 3-5 cranks of the starter. However this afternoon after the bike was sitting on the parking lot for 9 hours, the bike did not want to start. I turned the key, waited for the fuel to prime, the pushed the button. The starter cranked 4-5 times but the engine did not started. I tried about 5 times, but then the battery ran out of juice. Had to jump start it with my buddy's car.
I'll check the battery and charging tomorrow.
Question:
How should I start the bike normally (the bike started without any problem in 75 degrees temp this morning)? Do I need to use the fast idle to start? It was really hot outside all day.
Thx!
This morning the battery gave 12.19V avarage, after I started the bike it was charging with 13.7V avarage, however when I reved the engine to 5-6k it dropped to 12.8V. Anyway, I rode the bike to work, will see what happens tonight (this time I brought cables :) ).
Yeah - my battery was always dying too. Even after the overnight tender routine, after riding for a bit and letting it sit it would die. I checked all electrical and it was good. Did the charging mod, never had another problem. Well there was that 1 time I left the key in the on position when testing out my new lights - but that doesn't count. By the way, before the charging mod, I had a new battery in it that was approx. 2 months old. Definitely do the charging mod if you don't have any electrical issues! :pirate
From what you described it sounds like your battery was a bit low,
put it on a charger overnight, get it fully charged, and your bike should keep it topped up. I do mine once a week with a tender I plug into the bike, and I've had the same battery for years, as did the previous owner:).
A simple TRE fixed my starting problems - used to take 4 - 5 cranks, now it's one or two cold, and hot. I always use the fast idle, unless it's been running within 30mins.
If you have an alarm, check that it is not draining the battery, this does happen; I've taken the fuse out of mine, and put it in when I need to use it. If it's in my shed, I just stick it on the tender.
You may as well check your TPS - it's a 2 minute job.
You've got yourself a keeper - don't be put off by a few maintenance issues.
I bought my 1998 TLR last November. It had a real hard time starting. I had to charge the battery every two weeks. This spring, I splurged for a new battery. When I put in the new battery, I found that the guy I bought it from, ( a mechanic) had put the wrong size battery in it. I bought a new Scorpion and now it strats right up.
Discussion Starter · #8 ·
I cleaned the BMC air filter (new one is on the way, out 4 dealership around here none carries parts for the tiler). Changed the spark plugs, oil, filter. Now the bike starts up much easier.
Something that helps mine start quickly is allowing the fuel pump to prime a couple times. First start of the day, just cycle the switch another time or two and it might help ya.
