just got back from work but on my way home
noticed the rev needle bouncing looked at the screen and check was showing
tried to get it in dealer mode but no joy
anyone know whats up
Can't get it into dealer mode with 'CHEC' showing.
Sounds like a bad connection(s) between the ECU and the dash. Any other things playing up on it?
Try reseating the plug on the dash and the ECU too.
noticed the battery + connection was a bit loose maybe the cause
will try it out later after ive remade my number plate hanger
spot on guys
checked the plugs to the dash heard a click then turned on ignition
everything hunky dorey:)
