So to start off my cpu crashed so I cant look at my manual my 99 tlr has been having problems since I put in new motor set tps synced tb's bit had a digital manometer so it was hard to read bc it jumps around quit a bit I got random backfiring in intake. I was wondering which lines from the fuel pump are supply and return bc I can take the hose off with the white two prong clip out turn om the fuel pump and it sprays but if I takr off the other line that leaks out,the tank which I presume is return and tun on pump I gey nothing from that line while cranking or just primed. Is this normal?
