Something I do want to mention. Maybe if there is and interest, someone could cut and paste to a specific injector post.
I felt the there was an issue with the fuel supply. Engine was spotty at the 3000-3500 rpm range. When the air box was off, I looked to see the injector function, and noticed a very "drippy/droplet"" input. I had heard about Mazda injectors fitting so I researched and found these. Info below.
OEM TLS injectors on Ebay are 200 pounds EACH from the UK.
These replacements are $60 each from the US.
Mazda RX7 460cc/min Denso Red Top P/N: 195500-1350; Mazda P/N: N32613250
They work FANTASTICALLY!!! Beautiful fan spray, much better/even mixture fuel/air. Power pour is smooth and there is now a distinct powerband surge at 4500rpm to redline.
The only thing you need to do is cut and splice the different connectors. I decided to solder and heat-shrink with small paddle connectors for easy/quick re and re.
EV1 OBD1 connector.
EV1 OBD1 connector.
