I could post you some of what we have at work if it would help, pm me your address. I've got 2 thicknesses that you could glue on if it helps. I assume you mean for the bits around the inlets,
I could post you some of what we have at work if it would help, pm me your address. I've got 2 thicknesses that you could glue on if it helps. I assume you mean for the bits around the inlets,Hi all, anyone got a great 'use this stuff instead' fix for replacing the foam on my tlr airbox? Robinsons want £9 each and it's only a strip of foam!
Rich
