I need help to remove the bolt that hold that holds the two engine mount brackets to the TLR engine.
The brackets are monted to the front of the engine and join to the frame.
There is a bolt that looks like it goes right through the head holding both brackets to the engine.
I obviously need to hold one side stationary and turn the other. Is it a clock wise or a anti clock wise turn to undo it ???
As it doesnt want to go anywhree and I dont want to strip of snap the bolt.
help
Should be standard. After taking 3 bikes apart now ive found alot of the engine bolts have some nice corrosion on them. Nice white oxidation.
on older coroded bolts it sometimes helps alot if you first break it loose by tightening the bolt...i guess this works because there is usually less corosion on the inside where it in not expossed to everything...???...
