Hey Tubby!
I know the parts for the rebuild of the front forks (Racetech springs & gold valves, shims, seals, new oil, etc.) could be less than half that if purchased off eBay (I have seen the springs and gold kit for under $300 if you keep an eye out). I haven't rebuilt my forks, but there are good pictorials on the process and it is fairly straightforward if you want to give it a go. I plan on doing it next winter.
I have an S, so my rear end is different than your swinger, but I am seeing Showa shocks for cheap cheap. So cheap that you could do your own fork rebuild and have the Showa spaced and sprung all for under $700 maybe. And if you find you don't like the rear you can look into an Ohlins or Bitubo in the future. I have to figure if you are running the rotary damper that pretty much any rear end upgrade will make you feel like it was an upgrade. I am hoping to put my rear damper back together by tomorrow and I will pop you a picture. It's an S with the S swinger, so I still retain my stock spring, but hopefully I gave you some info and not just rambled. :laugh
