I'm in the market for some new rearsets for my 97 tillis.
I found some on eBay and was wondering if you guys could
check them out and see if thier worth my money.
The item number is ( 190337539647 )
They look ok, but be aware that the 2 bolt fixings are more prone to snapping your frame lugs in a crash.
If you want to save your frame consider these, not the prettiest but can be polished and very strong as I've just found out :laugh
Hi stretch they look good but they dont have much ajustment, gillies are the best fitted them to my tl 1000 r i recomend them, much more ajustable
Go with the sato rearsets. They are the best rearsets I've ever rode on. Well worth the money. Little more expensive then the other options but worth everypenny
http://www.oppracing.com/products/464-suzuki/
http://www.indysuperbike.com/customer/home.php?cat=30787
http://www.kneedraggers.com/list/1254/manu/Sato/Suzuki/TL1000S
(I have been told that the rearsets are the same for the R and the S, you can check part#'s or one of the all knowing TL gods can confirm)
heres a few places. I cant remember where I ordered mine. I think it was indysuperbike.
I like the sato's because the controls are double ball bearing. They are silky smooth.
MAKE SURE YOU FOLLOW INSTALL DIRECTIONS WITH LOCTITE.The bolt that holds the shift rod has a rubber spacer that makes it move smoother so you cant tighten it enough to keep it on without loctite (you don't wanna know how I know this)
