Hello everyone. I've managed to get hold of a pair of the rear fuel tank support brackets which attatch to the front top of the seat subframe (a recall item I believe). Unfortunately I couldn't get any rubbers, so I bought some Bandits ones. They're the same hole fitting but much larger. Does anyone who has them fitted have the correct dimensions, ie. height, width, depth etc. and are they square or round. A picture with the dimensions (in millimetres) would be greatly appreciated. Many thanks.
Regards
Tim
Thanks Tony. Those dimensions seem the same as the rubbers that sit halfway along the tank and sit on the top tubes. I've fitted the rear brackets (as with most Suzuki bits, there's an R and L stamped on them) but with the tank down I can't get in to measure the height needed.
Regards
Tim
They are Bandit rubbers. The two small ones are just one of the big ones I cut in half. The small ones are what I used and work perfectly. I have put the dimensions in this drawing 馃憤
65091
