Rear shock mod tips
32566 Views 66 Replies 18 Participants Last post by  snowblind
Hey guys
Ok I am 100% sure on fitting a CBR600 2/3 rear shock in so to replace the existing fabulous idea they threw in there;-)
My problem is this....when you look up how and where to fit it, why do I see images of the showa shock fitted to the left and also then in other pictures its fitted in the centre????
Has anyone fitted one and whick fixing points did you use?
Im ok with sorting the spring ratio and all that jazz as a mate at work used to set up hondas stuff but we can't get our heads round the differing pictures.....
HELP and CHEERS:)
1 - 20 of 67 Posts
Hi I have Cbr conversion on my fighter
On hols @ mo will pop some pics up my
Thread when get back
violator what year CBR600 did you use? graememg2 the CBR600 2/3 is that a 2002 / 2003?
Thanks
Thanks
Yeah the 02 or 03 Showa cbr600 rear shock I hear is a good replacement
using matty brackets will mount it in the centre using an f3 showa unit.
Good stuff cheers:)
Will get onto spring ratio now and sort it
This is on a TLR? You can do whatever you can fit...
I put an Ohlins on the far left and a Bitubo on the right with the SOAS linkage. But that's my sickness. Given a choice I stay away from the rear cyl exhaust stub pipe.
Me and a friend are looking at milling a bracket ourselves out of ally just as an experiment to see where we get to so should be fun....there's no rush though as the weather is well and truly on us now over here so the bikes up on stands for a good winter scrub down and inspection
Suspension part Auto part Suspension Coil spring Vehicle
CBR 600 RR converted shock to fit an R arm in a Tillis.
This has been done for 10 years now. I've compiled everything I can find in those threads. Here it is:
Showa Rear Shock Mod
This procedure is about replacing the stock TL1000R rear shock with a better shock. The stock shock pictured uses a rotary damper for compression and rebound dampening. The assembly works poorly and weighs 14lbs with the spring assembly. A new Ohlins or Bitubo shock costs $1500. This substitute can be made for about $200. This modification only works for the TL1000R. Not the TL1000S.
Showa Shocks that work
MAL-601 - Most popular for this job. 11" long - 46mm pistonOD - 49mm BodyOD - 95-96 Honda CBR600 F3
MAL-621 - Similar to the 601 - 11" long - 46mm piston OD - 49mm BodyOD
MAL-G01 - 11.5" long - 43mm OD - 40mm BodyOD - less damping range adjustment
These are the only shocks readily available that were found to work because of their length. The click stop adjuster on the bottom of the Showa shock moves the spring .050" per step which is 50 lbs of spring preload. Therefore, 5 steps is 250 lbs at 1/4".
Remove the silliness they call a rotary damper and the spring. Next is the frame cutting and grinding. There are 2 tabs that need to be ground away to make the Showa shock fit. THIS WILL BE A PERMANENT MODIFICATION. IT WILL REQUIRE WELDING TO EVER GET THOSE 2 TABS BACK. See picture on what needs to be cut away. You will have to cut deeper than the original tab mounting surface to get enough clearance for the new HyperCoil spring.
THIS IS A PERMANENT STEP. NO TURNING BACK!
Auto part Fuel line Automotive engine part Engine Metal
Auto part Automotive wheel system Pipe Wheel Fuel line
Next, drill out the lower shock mount bushing from 10mm to 12mm. The stock bushing is 10mm ID x 17mm OD x 39mm. It is hardened steel (Rockwell 40), so you will need to bore it out with a carbide bit. Drilling does not work. A bearing with a 12mm ID was sought at a bearing supply house, but was not found.
Tool
You'll need a HyperCoil rear spring ($80 on Ebay) that measures 6" tall and 2.25" ID with a weight rating of 1100 lbs for a 160-200lb rider. Use an 1150lb spring if you weigh over 200lbs. You could use the existing spring that comes on a Showa MAL-601 but it is too soft with an 800lb rating. You might think to ratched the pre-load adjuster all the way up and leave the stock upper spring perch in place to increase the rating of the 800lb spring, however, the spring rate is too hyperbolic and bottoms out too fast. This blue spring are also for sale at www.hrpworld.com with a brand name of HyperCoil.
You’ll need motorcycle spring compressors to remove and install coil-over springs. I paid $33 for one on Ebay. Spring compressors for a car have fingers that are too fat and won’t fit within the spring. Others have tried using ratcheting cycle-straps too, however, a short spring with a high weight-rating will not move enough using cycle-straps.
Next, the bottom spring seat of the shock can be used as is OR you may need to grind the top-half of the stopper blocks away to get the bottom seat to sit lower than it is originally. The 2 tabs are spot-welded on on both ends.
Again, the click-stop preload adjuster on the bottom of the Showa shock moves the spring .050" per step which is 50 lbs of spring preload.
The upper spring seat may not go high enough so you need a part machined to replace the original Showa seat with one that goes 1/4" higher. I've seen it made from steel, however, aluminum works too which would be less expensive and be lighter.
Others have used these shock settings
1/4 turn out from bottom for compression.
1/2 turn out from bottom for rebound.
If I could put more pictures in, I could go into detail with the last 2 paragraphs. I'll just try to explain better below.
Adjustable Pre-Load Spring Seat/Perch
The bottom spring seat of the shock can be used as is OR you may need to grind the top-half of the 2 stopper blocks away to get the bottom seat to sit lower than it is originally. Once you take the adjustable ring off, you'll the 2 tabs I'm talking about The 2 tabs are spot-welded on on both ends.
The upper spring seat will not go high enough for a 6" spring so you need a part machined to replace the original Showa seat with one that goes 1/4" higher. I've seen it made from steel, however, aluminum works too which would be less expensive and be lighter. :banghead Wish I had more photo space.
This describes it perfectly mate and seems reasonably straight forward once I get the parts together:)
Now to source a good shock and refurb it.
I finally found a machine shop nearby that can make the aluminum sleeve for the upper spring perch. 80 US dollars!! That's the cost of a spring. That puts this project over $220. I'm considering a 900lb 6" spring instead of the 1100lb spring. Then I can use the Showa steel upper perch. If the original perch makes the spring area 1/4" tighter, that's 250lbs of preload. 1100-900 is 850. I rounded up to 900.
I've got a suspension specialist in town who's son I used to teach swimming so he said he will sort any issue I have with refurbing the shock and setting up the new spring
Not what you know it's who you know:)
Faulker springs are $55 for a 6" x 2.25" + shipping. That's a good price if you live nearby. I'm US.
will look at shipping costs to GB cheers
Cheers gaztl1000r that list is perfect:)
demon tweeks sell them, but you might as well deal direct
hi im looking to do the showa mod without cutting the frame to bits.so if you manage to make some brackets and want to sell a set ;) id have cash waiting :)
1 - 20 of 67 Posts
