1 - 2 of 2 Posts
It's raining today so i'm out in the shed fitting Van's goodies - done the rear ressie and have taken the clevis pin out to twist the nut back on to the pushrod. As far as i can tell there are 2 adjustments ie: having the pushrod in the correct length, brake lever up/down. Is there a starting point for the pushrod and clevis nut to be in to make things easier? Any help appreciated :confused
Ozzie
Manual says the pedal should be no more than 65mm below the axle it rotates on :O I think there's only one adjustment though?
1 - 2 of 2 Posts
