What is the inner diameter of the rad hose on the right side of the TLS?
I guess it is the same on Rs and Ss but if there is any diff, I want it for the 97 ...
Anyone having their coolant system apart and able to measure? :O
I have it apart, can measure tonight if I don't forget it :D
I think it's 1 inch. Ask Doab, he had hoses made.
1 inch inner diameter is correct. Or about 2.5cm metric.
The flanges on the radiator are about 2.5cm as well and extend to 2.7cm at the end.
Yeah,
It is very close to 1 inch. It is slightly smaller than that as you have to massage that 1 inch hose a bit in order to slide it on the radiator & water pump spigot.
Thank you guys...
I am thinking of replacing that hose (maybe the others too) so I'd like to have done my homework first :)
