Hey everyone and happy new year, I have been having the issue that many others seem to be having with the battery either not recharging fully or not enough power being sent to the coils to actually cause a spark. I have taken the stator cover off of my 2001 tlr and done voltmeter tests to see if it is bad and I’m pretty certain it is still good. I got 6-6.2 ohms on all of the leads and no closed circuits between the positive and negative. I also tested the r/r using the same method and I think it is good as well. I did find some corrosion in the electrical plug so I think this was the main cause of my problems. (I will be adding pictures to this post). I started checking the other connections and found corrosion on the yellow connector that goes to the headlights which I think I read may also cause a big voltage drop when starting.
I plan on doing the “charging mod” but was wondering what size wire I should use and if I just leave the other side of the connector floating around under the seat? I am also going to do the “+ mod” but wanted to ask if there is any specific relay I should use. I was planning on using a 30A relay and 20A in-line fuse.
If anyone has any tips for any of these mods or can look at the pictures and make suggestion that would be great! Thanks!
