1 - 16 of 16 Posts
So i want to make the following mod this winter: Inlet cams from the R in my S, my S inlet cams on the other side of the head as outlet cams.
The inlet as outlet should not be so difficult with hints and a manual, but the R inlets can't go straight into my 99 engine because of the different tooth depth on the R gearwheels. I need to go the way as for example Fiche Man did, pressing on S gearwheels on the R cams. I cannot do this on my own, dont have the tools or even any measurement gauges to correctly press on the wheels. In fact i wonder how a machine shop will do that correctly, as Fiche Man said the cams could rotate when pressing and there are no marks to hold on?
If i remember right, a member here used the R cams without pressing the S gears on and had an engine failure?
i'm runnig R cams in my S. just swapped en straght over. not had any problems. put them in 2 years ago now.
Hi Jagboy, did You notice a different depth of the gear tooth? The newer S engines, from 2000 on i think, have the R driving gears.
I'm afraid to put the cams in without taking care of the gears.
when i fitted mine i bought tlr idler gears. they are a straight swap and then you know nothing's going to break
i cant say i noticed any difference in tooth depth. but then i was told they were a straight swap,so i didn't measure them.:O all seems fine to me. might get them reground at some point in the future. :devious
chraika1 said:
why dont you guys just go by an R? too much for you to handle?:lol..
Ash
bloody kids:laugh :laugh
That's the way I'd do it
Bernhard has done this Mod also and he is in Germany.
You'll have to think about the target for the cam sensor. I think it's in the rear exhaust cam, no inlet will have the pin in it.
Discussion Starter #12
@ Tornado: Would be perfekt, but i have to take the Motor out for this. The frame routs in front of one idler gear, so tools cant be used until the engine is lowered.
@ Steve: Ok, thanks for the advise with the sensor.
looks like that cam sensor is on the rear intake cam so that will not be a problem but you will lose your auto decompression on start up .that is on the exhaust cams
Banned
I wonder if anyone has done the opposite and increased the exhaust duration/lift via a TLR inlet cam ?
I have right now 4 TLR inlet cams in my 2001 TLS :)
Good for my big headers:devious
You have 4 TLR intake cams in your TLS? WIth what pistons? I see that's more exhaust lift than even the Web Cam aftermarket cams!
Do you think the stock exhaust cams are originally made too conservative for emissions or fuel mileage reasons?
Seems to me that if I could use TLR intake cams as exhaust cams in my TLR, I might be able to get just aftermarket intake cams for half what the full set goes for. I wonder whether there's any interference issues with the Wiseco 12:1 flat-top pistons?
1 - 16 of 16 Posts
