questions, questions, questions lol. '97 TLS
465 Views 4 Replies 4 Participants Last post by  stu_m
So then, project shoestring TLS is underway, got a few questions.
Oil, fully or semi synth.
Clutch friction plates, oe/ebc/barnet? (have five or six bolt set up available)
Swingarm, any advantage to fitting a TLR arm?
Rear shock, anyone got a template/drawing for the damper brackets for r1 or similar conversion? Capable of making the plates up myself.
Race fairings, UK, where can I get tls race plastics? Do NOT want a full fairing just bikini style.
Thanks
Jamie
Thanks
Jamie
when you say plates for shock, you centrally mounting it ? i have two sets for either left pm me if interested last ones i have left
Either will do. Tesco 5/40 is fine.
http://www.skidmarx.co.uk/suzuki/10545-suzuki-tl1000s-race-top-fairing.html
Cheers
Thanks fellas, pm sent to adstl.
I use EBC plates in the clutch with no problems I run a 5 bolt clutch with no probs too
while its apart send the center cam set off to sam and have it welded up it will be the best mod you do to it :thumbup
the R arm has less flex and looks good...I'm in the middle of fitting one now
