1 - 3 of 3 Posts
Question time :)
Q1. When replacing the swimgarm pivot shaft, What torque is required to secure it???
Q2. On the rear sets most of the bits unbolt, but on the LHSide, I've removed the shift rod but how do I remove the ball pivot joint ???
cheers
Question time :)
Pivot shaft =11.0lb-ft 15N-M
Pivot nut=72.5lb-ft 100N-M
Pivot shaft lock nut=65lb-ft 90N-M
Not sure on this one,dont think it comes apart???:O
cheers
Q2 A: You're not supposed to remove it, if you do, you're going to have a hard time refitting it / getting it to stay tight in the lever.
It's a press fit and I think the other end if flared / punched / riveted or something.
1 - 3 of 3 Posts
