for some reason my bike wont rev past 8k rpm any ideas?
throttle response is fine and i just got the bike and its been like thisHow long have you owned the bike?
What symptoms led up to this limitation?
Have you noticed anything esle odd?
Did this problem just start all of the sudden?
Is the throttle response normal in the lower revs?
What did you change or work on during the last service?
Weak fuel pump.throttle response is fine and i just got the bike and its been like this
i replaced the fuel pump just didnt do filters what kind of injectors should i buyWeak fuel pump.
Clogged fuel filter.
Clogged injectors.
That would be unusual, but you can find used injectors on ebay, or new ones from parts houses, or even third-party items from the aftermarket.what if the injectors are shot
