1 - 15 of 15 Posts
Looking at getting a power commander v , (dynojet sku#20 055) for my TLR.I have Yoshi RS3 and air box mod.
Has anyone had any good or bad results.?
Seems alot of people using the comander 2 and 3. The new one I was told has an auto-tune feature which is a good idea, but I'd like to hear from someone how is using the commander v.
Cheers
There are some using the PC-V on their TLs (with good results), but rarely do they post on these forums. It seems most of them are on the Facebook groups these days.....
I hate FB groups, I miss the good ol days when forums were a hive of activity. To many idiots with no clue in FB groups, Forum MODS seem a lot tougher on crap/
I was advised to switch to the PCV because its more stable and still supported by Dynojet. Working great on my bike. The canned tune isn't bad, but I have a built motor so left a lot on the table compared to a custom map.
I just changed from a PC2 to a PCV on mine ( suggested by the tuner) RS3 and pipercross filter . it came from dynojet with tune in it
fuel trims were good HP 110.33 torque 67.69 Spun a rod bearing three days later lol
My bike came with the PC3, while trying to update it I bricked it, PC gave me half off a PC5 with trade in of the PC3, took the bait and it seems smoother. also from what I was hearing most shops don't want to deal with the older ones as they aren't as tuner friendly as the new PC5. No regrets either way.
Discussion Starter · #8 ·
Thanks for the info. Are you using the PC5 by itself, or with an auto tune single channel or a Power Vision to optimize your A/F ratio?
as far as i know there are no extra plug ins available for the TLR.. i just plugged it in, added the yoshi pre configured map and off i went. it's plenty of power and smoothed out the throttle response. my previous problem that made me want it was because of the jerk at low speed when i gave it throttle. already had the airbox mod and still didn't like it.
planning to get it dyno tuned later this year with custom fuel map after I get front shocks redone.
I had a PC2 on mine , I took it to a dyno tuner , he also said that dyno jet would send me a PCV with a map preloaded
I have full RS3 exhaust and a pippercross air filter, with the map in it it made 110HP and 67ftlbs torque, room for inprovement.
but then it spun a rod bearing shortly after.. swapped out the motor, but haven't been back on the dyno yet.
I would like to add a auto tuner if possible, sent Dynojet a email, waiting now
Discussion Starter · #12 ·
I've talked to a local dyno tuner that has yoshi supported equipment. He wants to dyno my bike and thinks he can adjust my ecu with out adding a power commander. I have ps3 cans, air box mod, k/n filter, TRE, and 1/5th throttle (I want to go back to 1/4) .It has 17/41 cogs, It is very touchy in lower gears. I too want to smooth the power but keep it strong in derlivery. Next week I'll get the bike on the dyno and we'll see what the results are.
Discussion Starter · #14 ·
Re- no plug-ins. One the top side of your 20-055 PCV don't you have 2 expansion ports. One for POD-300 and the other for Auto-tune kit?
1 - 15 of 15 Posts
