i bought a power commander for my tl and for some reason cant get the mapping to download any help would be appreciated
Also make sure the usb is cable is properly seated at pc3, sometimes they need to be pushed in with a little extra force until it clicks in
http://www.powercommander.com/303-411.aspx
Its not like i know what i am doing but i just .......clicked on a map..clicked Run (not Save)..where it said Browse,i used Desktop... OK then Unzip....closed the box and the map was on the desktop opened with a double click......You should be able to grab the map form there when you want to load it to your PCIII.
nothing happens i download it unzip it then nothing
Its not like i know what i am doing but i just .......clicked on a map..clicked Run (not Save)..where it said Browse,i used Desktop... OK then Unzip....closed the box and the map was on the desktop opened with a double click......You should be able to grab the map from there when you want to load it to your PCIII.
I just tried it again off the power commander link with no problems.
When you have unzipped it as above you need to go to that location.I used Desktop (main computer screen) and there it was as an icon,double clicked it to open.
