Hi Boiz,
I have a switch mounted on the fairing of my TLS that I assumed was the fan mod, but the fan doesn't come on when the switch is thrown. Upon further investigation, it turns out that the switch is spliced into the pink wire that comes from the larger plug on the ECU.
Is this a recognised mod? If so, what its it supposed to do as the only difference that I can detect is a slight variance in idle revs when the switch is thrown.:confused
Cheers,
Dan
Cheers,
Dan
