1 - 10 of 10 Posts
just checked the tappet clearance on my TLR99, only to find some 1 has been playing around before. :coocoo
it looks like the pink wire has been cut from the connector and jointed with a resister to another wire on the same block.
i am assuming that this is for the gear position sensor as the plug is located under the tank on the right hand side (if your sat on it)
am i correct in what i am thinking, that this is someone attenpt at a tre mod:confused
managed to join the wire back togeather, even with the small amount they had left on the plug MESSERS:banghead
Sounds like a basic TRE mod.
say goodbye to first and second gear wheelies.
go to wotid.com and look around for a better circuit.
With no TRE the timing is retarded in the lower gears.
Not exactly NO first and second gear wheelies,but less likely.
Stu is prone to exaggeration;)
To be sure to be sure :laugh
2 X 15K in parallel = 7K5 probably worked as a 5th gear (6K8) TRE, so no great big deal :thumbup
No someone had already done the cheap resister mod and used proper terminals on the gear selector side, then some messer just cut the pink wire and soldered a resister in, instead of using his eyes first.
will measure the resister next time
1 - 10 of 10 Posts
