1 - 2 of 2 Posts
Hey all...
How does one adjust the pedal height on a TLS.
Do i move the collar one notch where it meets the splined shaft?
Any pics of where the gear changer should be in neutral?
Thanks
Undo the lock nuts on the shifter rod between the lever and the actuator. Turn the rod CW or CCW until you have a height that suites you.
There is a standard degrees setting in the manual, but I always drop mine.
1 - 2 of 2 Posts
