Had to run the bike straight off the ecu to get home, when I plug the PC back in the fuel pump won't prime, but without it, it will and run properly. Beats me?
Your wiring loom is probably pulled out a bit on the plugs. They don't service them anymore so your best hope is to have a look and see if there's any loose wires or pins pulled out that are obvious and fixable.
Join the club. never had a fuel pump problem. Mine would give a TPS code and run like dogshit and usally stall mid corner in a real fast sweeper or something like that.
I have a 1999 TL1000s setup with a Smart TRE and it runs fantastic, starts up 1st time every time no loss of power anywhere no complaint at all the PCIII has never let me down. If I remove the PCIII bike runs like SH*T but you need a good map!
Regards
Carl
A forum community dedicated to Suzuki TL sport bike owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, racing, troubleshooting, maintenance, and more! Open to all TL1000R (TLR), and TL1000S (TLS) owners.
