1 - 1 of 1 Posts
I emailed Dynojet to get support for Power Commander II and thought I'd share the files with you fine folks. The USB to serial adapters, which are common in the marketplace, are also problematic. A true RS-232 serial port is recommended. Also, make sure your ports are set correctly and only ports 5 and below will work with the software.
Here's the link: You're welcome
1 - 1 of 1 Posts
