Do any of you folks think a PC3 would be able to tune an original 97 ECU ? My Teclusion TFI does an ok job but I have it tuned way rich on the bottom end to get rid of the surging/stumble at 3500 rpm which it does but at the cost of poor gas mileage and probably a little bottom end snap .Anybody on this site have experience with the original Ecu and a pc3?Would it be capable of actually leaning out parts of the Stock fuel mapping?
It doesn't tune the ECU, it modifies the signal coming from the ECU IIRC. Otherwise, yes - if you fiddle enough you'll sort it out.
The general consensus is that the original ECU is way too rich ,being on the cold setting what with my temp sensor in the wrong place .However , when I did the airbox mod and Full yosh it was way too lean with the pipes running white hot using the stock(original ) ECU. So I had to add the TFI to richen it up.
The Teka, Yosh-box (and derivatives like the JoE & Mac-boxes) all change the map within the ECU - like overwriting a file on your computer. The PC takes the output from the ECU then messes with it & send that to the injectors etc. I forget the details but the way the PCII & the III work are slightly different. However the end effect is the same.
So if you get a PC you'll have to write a zero-ed map to the ECU THEN fiddle with the PC map or it'll run like poo-poo's ... I know, I've done it :D
