1 - 8 of 8 Posts
I installed the pc2 and forgot about the tre, ran the bike about 10 miles for about a week. I was having stalling problems and then after asking about the metal noise I remembered making a tre going to install it and finding one already in its spot :coocoo so I took it off today and now when I really let loose on the throttle the engine will stop producing lurching me forward on the bike, backfiring/popping, and then suddenly taking off like a raped ape. I tried it out a few times (stopped), it only happens under 4k rpms, happens in all gears to include neutral, then I tried a few times rolling in a higher gear for less jerky motion and the same process happened. I think it may either be something jarred during an off I had about a month and some ago, or the fact that I have the euro full yosh map on the pc2. Any ideas?
How does it run without the pc2? What are your mods?
Sounds like a map problem
octofinger: I will run it without the pc2, without the pc2 and w/ the tre it stumbles at low rpms but smooths out as i go up.
steve tls: would there be any difference between the euro full yosh map and the us full yosh map?
You'd have to look at the numbers in both maps to see how much and what the differences are.
send me an email to ([email protected]) and i will attach the map file and return it to you
1 - 8 of 8 Posts
