1 - 15 of 15 Posts
Had my bike on a Dyno today but when we went to program the PC nothing would happen when we held down all three buttons. Has anyone else had this problem or am I doing something wrong? We tried with key on ,off, etc. but no luck.
If you have the bike on a dyno, hook it up to a computer/laptop with the DynoJet software and tune it that way.
:O
:O
I thought you only did that to change the map, the map is good , just trying to fine tune it. I'm certainly no expert and the guy with the dyno is pretty new to it, he claims this is how he always adjusts others.
I would think manipulating the map through the computer would do much more "fine tuning" than playing with the low-mid-high on the PC. I've never even messed with those buttons on the PC.
I don't know the answer as to why you couldn't adjust it via the face plate buttons, but the computer software does more fine tuning compared to button tuning.
Ha! join the club. I'm on my 3rd one.
I'll learn one of these days.:coocoo
Bike needs to be running, not just turned on? Or the PC just goes off with the pump. Thats all i can think of.
+1:stupid...PCII gets its power from same circuit as fuel pump hence only works if fuel pump is running...newer ones have a battery adapter that will allow you to make adjustment without the bike running i also think this is particular to the TL's other bikes run power a little different...my $.02 worth
Discussion Starter · #10 ·
That makes sense, when I would turn on the ignition the middle PC lights would flash then go off when the pump came on. I'll try starting the bike and see what happens. I'm pretty sure the PC works I'm just having issues programing it.
for programming it doesn't need to be on but the fuel pump does need to prime as previously mentioned - i don't think you can load the map with the bike turned over.
on a seperate note: what pins does the nine volt go to for power with the portable power source?
it is up in the shop i will let you know ..
It needs to be on for the fuel pump to prime. :coocoo
And you can load maps with the bike running too.
Walt, fine tuning should be done via computer link to the PCII. Using the buttons is rough. I wouldn't trust this guy, take it elsewhere.
Discussion Starter · #14 ·
The guy who has the shop is 65 and has raced and worked on bikes most of his life. Like myself he isn't very good with computers though:banghead
Thanks to you guys I do have more knowledge than when I started. I did try everyway of turning the bike on and still had no luck with those damn buttons. I'll try hooking it up to the computer next. I did two runs on the dyno my best being 124.5hp @ 8200rpm, 79.73lb torque, 91.42mph.
by on i meant the engine turned over.
1 - 15 of 15 Posts
