ok guys sorry to say Both my TL1000S& Tl1000r Are gone (But not forgotten )
I have a lot of spares
Tl1000R Motor BAD BEAring -$300
TL1000S Motor BAd bearing -$300
S Radiator -$55
S-CAns -$45
R-Cans- $45
S- Rear Rim Slight Bend -$45
R- Wiring harness-$65
R-Throttle bodies-$65
R-ECU-95
R-Clutch-$65
R-Levers-$20Each
R-Air box -$45
R-S/ side covers $CLutch cover $55
R/S Clutch side Cover w/Water Pump $125
R-oil cooler-$65(2)
R-tack$65
R/S rectifier$25
R /cylinder/Piston-$75Each have 2 or 4
IGnites-$45A SET(2)
r rOTORY dAMPER-$35
S- brAKES SYSTEM mASTER TO CALIPERS & LINES-$125
S-CHAIN GAURD $10
BAG OF VALES$75 DONT ASK I THOUGHT THEY WERE BENT SO I KEPT BUYING ANOTHER SET(2-3SETS
Alot of other items
oR PACKAGE $750 obo FOR ALL
aLL LOCATED sOUTH JERSEY 20MIN from Philly
LArry
text or call or email
60924753fifty
[email protected]
parts
sorry clutch perch and slave and rod for hydrolic clutch
i do have a clutch that is soaking in oil was never installed ..
can i dibs that clutch for a bit
is it a complete setup?, so that i could take off my cable setup from my TLS
that is perch,lever all bolts, slave cylinder and bolts complete with pushrod?, how about lines?
ill double ck on the lines ill also ck on the lever i think i have just an s lever again will ck sat morning when i pull all of it out
