1 - 20 of 399 Posts
Super Moderator,
I can get pics on request.
Body Panels.
Tail Fairing with LED signals $120
Front Fairing $150 (nose, head fairing...whatever you want to call it).
LH Side $175
RH Side $175
Belly Pan $75
Front Fender $50
V Fairing $45
Gas Tanks $50-225 depending on condition.
Ram Air Tubes $30ea
Ram Air Tube Boots $10ea
Stock Undertail $25
Aftermarket Fairings, Front, Both Sides, Belly, Ducktail-Stock, no hump. $350
Electrical.
PC2 $130
Speedo/Tachometer $80
ECU $80
Turn Signals, Stock $15ea
Headlight $160
Tail Light $15
Radiator Fans $25ea
Complete engine harness $120
Headlight Wiring Harness $75
Right Hand Switch Block & Throttle Tube $70
Left Hand Switch Block $50
Frames.
Frame, Clean title in hand. $750
Frame Chromed, Clean title in hand. $1600
Subframe $100
Subframe Chrome $175
Swingarm $80
Swingarm Chrome $250
Brakes.
Front Rotors $100
Rear Rotor $25
Rear M/C and Resi. $60
Front Brake M/C $100
Rear brake torque arm $15
Brake Lines, Set, Stock $20
Front calipers $100
Rear caliper $30
Rear caliper bracket $15
Wheels & Suspension.
Wheel Front $110
Wheel Rear $110
Cush Drive/Hub $20
Cush Drive Rubbers $10
Rear suspension $20
Front Forks $150
Triple Tree Complete $80
Triple Tree Upper $30
Triple Tree Upper Chrome $65
Stock steering damper $30
Engine & Cooling.
Throttle Bodies $75
Stock Airbox $40
Engine mounts $50
Rectifier $50
Coils $40
Clutch Cover $40
Lower Radiator $100
Upper Radiator with fans $220
Radiator Fans $25ea
Overflow bottle $20
Switches & Sensors.
Sidestand Switch $10
Tip Over Sensor $10
Ambient Air Pressure Sensor $10
Intake air temp sensor $10
Rear brake light switch $10
Other Parts.
Yoshimura Carbon fibre bolt on cans. $450
Front axle $25
Rear axle $25
Swingarm Pivot Bolt $15
Front Seat $30
Headlight Bracket $65
Passenger footpegs $50
Rear Sets $75ea
Lock sets $80-150
Left Clip-On $30
Right Clip-On $30
Chrome Clip-Ons $90
Hydraulic Clutch, Complete Lever to Slave $100
Chain & Sprockets various..... $50
Chain guard $10
Exhaust heat shields $30
Sidestand & bracket $15
Fairing brackets (small L shaped ones) $20
If it is not listed, I may still have it and just forgotten about it....just ask.
HI, I am interested in the upper radiator without the fans. Do you have any pics? what condition? al brackets in place? Is it straight?
You can also e-mail me at [email protected]
where are you located?
CHas
Stock exhaust??? I need just the right side mid-pipe. If you have it, and there's no rash, can I get pics and how much shipped to 76006?
Hi Ian, can you send me a picture of the speedo/tacho as well? What's the mileage? Thanks
Hey SB there is a set on ebay in OZ for a $100AUD,check it out under tl1000r.
1 - 20 of 399 Posts
