1 - 20 of 74 Posts
Thought that i would start build thread as bike coming together. Most small, time consuming, things are done
so HOPEFULLY we dont have to wait year or so to see her ready :laugh
Some fact´s of coming bike which is ´99 S:
Engine:
-SV crank and rods
-`R pistons
-Slightly modded heads (mostly smoothed)
-1mm squish
-`S intake cam as exhaust-cam and `R intake as intake (when i get my camtool :banghead)
-Stock headers for while with open cans,something else coming, debends if i get money or time what it is, full system anyway :)
-Modded airbox
-`R clutch slave, used by k7 gsxr 1000 master
Suspension and brakes:
-k6 gsxr 600 forks
-k3 gsxr 1000 front calipers
-oem rotors
-oem rear brakes
-steel braided lines all-over
-1098 rear shock with ~11kg/mm spring
-oem swinger
Blings:
-speedking rearset
-open sprocket cover
-Suspension and front brakes :lol
-polished frame, rim lips, swinger
-oem electrics modded to keep up :)
-gapmod
-Clear led rearlight
Random stuff:
-shingden R/R
-healtech speedo corrector
-healtech GiPro
-16/40 sprockets
-metallic red
Pics to come :)
Gapmod, used undertray it had when i bought it, or rear-half of it. Some plastic sheet and fiberglass to turn it in shape. Some work still to do on it....
Had to do bracket for TOS, starter- and blinker relays found place on gapmod. Battery is temporalily going to be where pictured, probably moves
when i have money for Shorai...
Some random pics:
Ouzi, you are obviously a clever talented lad but (and dont take this the wrong way) like some of our young engineers, a little common sense go's a long way.
STOP USING WATER AS COOLANT ON A FRIGGIN ELECTRIC JIGSAW :banghead :scared
Discussion Starter #12
It´s pretty dirty and theres lots to do still, like polishing it :banghead
Haven´t seen shock spring either yet so i could work on shock bush lenghts, some electrics but mainly
earths and starter/battery cables, rear mudguard needs some sanding and clear on(and its carbon :banghead).
But most work done if i could get on road at beginning of next month :dowhat
If you get it on the road for the beginning of next month you'll have done better than most on here
:lol:lol
No problem Ouzi, and deff no offence meant :), just nearly crapped myself when I thought it was water, red to red, black to black, blue to bits :laugh
nice man, build looks good so far!!
Great work Ouzi, dont know if just thrown on for pics but your TOS is mounted upside down mate.
Coming along nicely mate :thumbup
1 - 20 of 74 Posts
