I have recently replaced the solenoid and the relay its priming It just doesn't sound like the starter is engaging the flywheel at all any ideas ?
Things i have done
Ive made sure the wires arent crossed
the battery is new
Rectifier and Stator are both new
65067
65068
May sound stupid, and I realize you said the relay is new, but double check the main fuse. Also check the other fuses in the fuse box. Are you certain you have good connections with the splices you made?
Whisnhunt88, I was looking at some of your past threads, and I'm wondering if this starter relay replacement is a continuation of your troubleshooting efforts since 2016, or have you been riding this TLR in the interim, and it just recently began to suffer no-start issues?
When did this TL last run?
So then, what I gather from your description, with this current problem, when you press the start button, you hear the starter motor spin, but the engine doesn't crank over. Correct?
If the starter spins but wont engage or crank engine.. Sounds like the overrun clutch or back torque sprag on left hand side behind flywheel magneto..
