1 - 13 of 13 Posts
can you do both the plus mod and the charging mod together? im pretty sure you can but i just wanted to check first. also how many of you have had the 30 amp inline fuse melt? thought i read that somewhere that some people had that happen. i am going to start this project this weekend and want to know what im getting into.:O
thanks
You can do them together. Buy a quality fuse holder and you should have no problems. Cheap ones melt. :thumbup
TLOTM Sept. '08
'+' and charging mods are completely independent of one another, so can do with er or both together, whatever - no bearing either way (but I recommend to do both!)
Fuse holder melting is because of poor electrical connection
See my comments in this thread and here
Avoid using an ATM size fuse/holder and be sure to use a quality component, even if going with larger ATO/ATC size.
got the 30 amp inline fuses from autozone. looks like 12ga line. good or bad??? gonna start this tomorrow
thanks guys
atm? its a normal size fuse for cars.
Discussion Starter · #8 ·
ok well its the bigger type fuse. so i take it thats good?
Discussion Starter · #9 ·
Ok did the charging mod that was pretty easy, but man the plus mod is a pita. I'm about 3/4 through it. Those coils suck to get at, hope it's worth it.
Thank guys
hey man, i was gonna do the plus mod too, where and what relay did you buy? i cant find that info anywhere...thanks
Discussion Starter · #11 ·
i just finished it about an hour ago. the relay was just a regular one i got at autozone nothing incredable. just make sure it has four male spade ends comming out and if you look at them there should be numbers 85, 86, 87,30. (good luck getting to the coil on the right side of the bike) they both suck but that one sucke more!!!.
thanks for the info....i know what ya mean about the coils, i pulled the tank and airbox off just looking around and those look like they are going to be fun. have you rode it yet and did you notice a difference??
Discussion Starter · #13 ·
ya i rode it. def punchier down low. but where i really noticed it was the mid to high rpms. def pulls harder. its nice:roost
1 - 13 of 13 Posts
