1 - 10 of 10 Posts
so recently i replaced my stater gasket and my bike is not starting or anything i hear the starter relay’s clicking i check the clutch switch on the kickstand and is just making clicking noise
Can you turn the crank over manually through the access cover on the left side?
Maybe you didn't get the gears back in place properly when you reinstalled the stator cover. Now, something is binding.
Or the battery is dead......
i took it back apart it still no crank no start
Well then, if the engine internals are not seized, it's time to measure the battery voltage.
Attach your meter directly to the battery terminals, and monitor the voltage while attempting to start the engine. Notice how low the voltage goes, and let us know what you find.
Hmm, where did everyone go..
It's always nice to know if the OP is making progress with the fix.
The sound of crickets is becoming quite common on the forums these days....
Yes, I agree. All that FB stuff just gets lost and it's hard to find, at least for me. The forums are like libraries, the stuff is always here, as long as the site is still up and running.
Discussion Starter · #9 ·
i tried replacing the starter relay nonthing changed the lights come on when i turn the key to the on position but when i press the start button nun thing happens
1 - 10 of 10 Posts
